This deep dive explores Appspace Conversational Authoring, an AI content creation tool that helps comms teams move from a rough idea to fully structured, engaging content in minutes – complete with layout, flow, and visuals.
Creating great internal communications should feel straightforward. But for many HR and comms teams, it’s more like staring at a blank page – for longer than any of us would like.
Strong internal content does more than inform – it builds trust, creates clarity, and keeps people connected across your organization.
But many teams are struggling to keep up. According to the latest Appspace research:
  • 72% of employees feel out of the loop on key workplace updates
  • 81% say workplace communication lacks consistency across channels
At the same time, expectations are rising. Employees want content that’s:
  • Easy to scan
  • Visually engaging
  • Genuinely useful
That means structured pages, clear messaging, and thoughtful design. Not walls of text but content people can quickly understand and act on.
Why is creating content for internal comms still too hard?
Even with today’s tools, creating internal content can feel slow and fragmented.
Common challenges include:
  • Getting started (hello, blank page syndrome)
  • Structuring content in a clear, engaging way
  • Building layouts with multiple elements (text, images, FAQs, highlights)
  • Maintaining a consistent publishing cadence
And while many AI content creation tools can generate text or images, they often stop there. They don’t help you create complete, ready-to-use, structured content.
The solution: Conversational AI-powered content creation
Conversational Authoring is designed to get you past the blank Story or Page.
Instead of starting from scratch, you simply describe what you need – and the assistant builds it with you.
From a single prompt, it can:
  • Generate a structured draft
  • Organize content into sections and blocks
  • Suggest layouts with text and visuals
  • Guide you from idea to publish-ready content
It works wherever you are in the process – whether you’re starting from scratch or refining an existing draft.
How does AI-powered content creation work?
Appspace Conversational Authoring is a creative partner built directly into your workflow.
You can “chat” with the assistant to:
  • Create new Pages or Stories
  • Expand or refine content
  • Improve clarity and structure
  • Keep content fresh with ongoing suggestions
Instead of switching between tools or manually assembling layouts, everything happens in one place – quickly and intuitively.
Pages vs. Stories: creating the right kind of content
The assistant supports both short- and long-form content formats:
Stories (short-lived, high impact)
Perfect for timely updates like:
  • Event recaps
  • Team wins
  • Announcements
Stories are designed to be visual, engaging, and easy to consume – like a great internal blog post.
Pages (evergreen, structured content)
Ideal for:
  • Policies and procedures
  • Onboarding resources
  • Department or company guides
Pages act as your organization’s knowledge base – clear, structured, and built to last.
How does using AI for internal communications work in practice?
Here are 3 real-world ways teams are using Conversational Authoring to create better content, faster:
1. Turn an idea into a structured page in minutes
Start with a simple prompt:
“Create a Page announcing our new hybrid work policy with key highlights and FAQs.”
The assistant generates:
  • A clear structure with headings
  • Supporting sections and bullet points
  • Suggested FAQs
  • Visual placeholders
Now you have a solid, ready-to-edit starting point.
2. Build rich Stories through conversation
Instead of manually assembling content blocks, describe what you need:
“Build a Story highlighting our Q2 wins with sections for metrics, team shoutouts, and visuals.”
The assistant organizes everything into a cohesive, multi-block layout – so you can focus on refining the message, rather than building the structure.
3. Maintain a consistent publishing cadence
Regular updates are easier when you’re not starting from scratch every time.
For recurring content, you can prompt:
“Create a monthly update with highlights, key metrics, and announcements.”
The assistant generates a fresh draft – helping you keep your message consistent, relevant, and visible across your organization.
A simple playbook for creating better content with AI
If you’re new to AI content creation, start here:
1. What’s your goal?
What does your audience need? For example:
  • Help new joiners get up to speed
  • Increase awareness of a policy
  • Share timely updates with frontline teams
Start with intent – the assistant will help shape the structure.
2. Add clarity with FAQs
FAQs make content more useful and practical.
Try prompts like:
  • “Add FAQs explaining how this policy affects employees”
  • “What questions might employees have about this update?”
3. Use visuals to guide attention
Great content isn’t just written – it uses visual cues to make your messaging easier to understand and remember.
Incorporate:
  • Images to break up text
  • Graphics to explain data
  • Visual cues to highlight key points
4. Stay consistent
Consistency builds trust and engagement.
Use the assistant to:
  • Generate recurring content
  • Maintain tone and structure
  • Keep your communication cadence on track
5. Invite feedback and improve
The best content evolves.
Encourage interaction from your audience, check your metrics – and refine based on what resonates.
AI content creation tools vs traditional content methods
Stage AI content creation Traditional content creation methods
Getting started Starts with a simple prompt; instant draft generated Starts with a blank page; slow to begin
Idea to draft Draft created in seconds from natural language input Manual writing from scratch
Structure & layout Automatically structured into clear sections and blocks Built manually; often inconsistent
Content quality Consistent, well-structured, and easy to refine Varies depending on time and expertise
Use of visuals Suggested and integrated as part of the content flow Added separately; often overlooked
Speed Fast creation process Time-consuming and iterative
Consistency Consistent tone, format, and structure across content Hard to maintain across channels and updates
Collaboration Acts as a built-in creative partner during drafting Requires back-and-forth between teams
Publishing cadence Easier to maintain regular, repeatable content Irregular, often due to time constraints
Improving content performance Continuous improvement with built-in analytics and prompts Manual updates based on limited insights
Focus for teams Easy to focus on strategy (messaging and engagement) Execution-heavy (writing and formatting)
How can you measure and improve your internal communications content strategy?
Creating great content is only half the story. Knowing what works is what drives real impact.
With built-in analytics, track:
  • Opens, clicks, and views
  • Engagement by department or location
  • Content performance over time
You can also ask simple questions like:
  • “What was our most engaging content last month?”
  • “Which teams interact most with updates?”
  • “Where are we seeing low engagement?”
This helps you continuously improve – and create internal communications your employees truly value.
FAQs
What is Conversational Authoring?
Conversational Authoring is a smart tool that helps HR and comms teams turn ideas into fully structured, engaging content in minutes. Instead of starting with a blank page, you describe what you need, and the assistant generates a ready-to-edit draft – with headings, sections, visuals, and layouts. It acts like a creative partner throughout the process.
What are the benefits of using AI for internal communications?
Conversational AI makes content creation faster, easier, and more consistent. Teams can overcome writer’s block, generate multi-block layouts automatically, keep up a regular publishing cadence, and improve engagement. It also frees up time for strategic work, allowing teams to focus on connecting with employees rather than formatting or structuring content.
Who uses conversational AI to create content for internal comms?
HR, internal communications, and workplace experience teams are the primary users. They use Conversational Authoring to create Pages, Stories, updates, and onboarding materials. It’s for any team responsible for keeping employees informed and engaged – especially if you’re managing multiple communication channels or distributed workforces – can benefit.
How do AI content creation tools help improve content over time?
The assistant doesn’t just generate drafts – it helps teams refine content continuously. It suggests structural improvements, integrates visuals, and works alongside analytics to show which content resonates most with employees. Over time, this leads to smarter, more consistent, and more engaging internal communications.
Can AI replace traditional content creation for internal comms?
Not entirely. Conversational AI enhances your team’s capabilities by taking on the repetitive, time-consuming tasks like structuring drafts and building layouts. Your team still shapes messaging, tone, and strategy. The result is faster, more consistent, and higher-quality content – without sacrificing any of that valuable human creativity or oversight.
Why does this matter for HR and internal comms teams?
At its core, this feature removes one of the biggest barriers to great communication: getting started.
It helps teams:
  • Move faster by dispensing with the blank page
  • Create richer content with structured layouts and visuals
  • Stay consistent across channels and updates
  • Focus on strategy, rather than getting bogged down in execution
And that’s where the real value lies.
When teams find it easier to create strong, engaging content, communication improves – driving connection, clarity, and engagement across your workplace.
Schedule a demo and see how Appspace Conversational Authoring can support your comms and HR teams.
